I was sent to trouble shoot a gfi brkr tripping on a hot tub, they had already called the spa guy and he said it was electrical and he had checked and everything is ok with the tub.
It is a 50 amp circuit with #6 thwn approx. 100 ft from panel to hot tub.
I (after removing the conductors from the hot tub board) megged the conductors from egc to all others, grounded conductor to all others and so forth, at 250 volts my reading was approx. 245 mega ohms, and at 500 volts it was approx. 550 mega ohms.
The megger charged to the selected voltage and held it just fine with all the readings (I usually notice the voltage not getting up to the selected voltage when there is a problem with the conductors).
With those readings I think the conductors are fine and the breaker holds ok when the conductors are unhooked from the hot tub.
I also tried a different gfi breaker and it tripped, actually looked like a short when it tripped because the lights in the house dimmed when tripping.
This tub operates fine on a regular breaker but when hooked to gfi it trips.
Home owner was kinda mad that I wouldnt leave the regular 50 amp in and left it unhooked till we can figure this out.
question 1) Do you think that those are sufficient readings with the megger to call the conductors ok?
Question 2) Has anyone ever had this sort of problem and if so what did ya find.
Thanks in advance for any info or thoughts on this.:smile:
