I've seen this link posted a few times here. It's a PDF version of a book that Biddle/Megger sells or if you join their site for free, you can download from their library. My question is, should the link be posted if Biddle/Megger is selling the book??SmithBuilt said:Here you go.
http://www.biddlemegger.com/biddle/A Stitch In Time.pdf
Or there are plenty of threads about megging just use the search function.
mdshunk said:You sure want to learn a bunch of stuff.
One word of caution... only learn so much at a time or you head will explode. I've seen it happen to many a good man.
himooo said:please i have the megger test equipment and I want to know how to measure the insulation resistance and I want to know - the megger tesr= insulation resistance test or not=
be very careful with the megger when testing your nadshimooo said:I am testing cables nad bus bars
wptski said:I've seen this link posted a few times here. It's a PDF version of a book that Biddle/Megger sells or if you join their site for free, you can download from their library. My question is, should the link be posted if Biddle/Megger is selling the book??
Ouch! With a 5000V megger?brian john said:you ain't testing my nads.......................
jghrist said:Ouch! With a 5000V megger?
That's too broad of a statement. Copyrighted whatever online isn't fair game!roger said:If it is available online it is fair game.
Roger
a stitch in time has a table inside the book. you go buy the equipment rating or rating of the cable. on romex, its rated for 600v so i set the megger to 1000v. if something is rated 250v i set the megger to 500v. usually any cable under 100megaohms is no good. theres also a rule of thumb of one megaohm per 1000 volts of rated voltage for equipment. i learned this from a combination of brian john, mdshunk and books (a stitch in time and insulation resistance testing by biddle megger,, printed in 1954 ) usually any testing book will talk in detail about insulation testing. if you happen to buy one you should experiment with it using pieces of romex, conduit with thhn, bx, and older cables just to see what you get. good luckhimooo said:I am testing cables nad bus bars
