M markatom New member Jun 3, 2009 #1 Can 22 gauge 2 conductor twisted with a drain wire and foil sheild be Meg tested at a 1000' run ? Having a intermitting open or close and can't catch it and is to be a major pull to replace cable. Thanks
C charlietuna Senior Member Jun 3, 2009 #2 A meggar would probably exceed the rated voltage of this class two wire?
480sparky Senior Member Location Iowegia Jun 3, 2009 #3 If you 'catch' an open or close, what do you intend to do to fix it besides replacing it?
76nemo Senior Member Location Ogdensburg, NY Jun 15, 2009 #4 How are you going to "catch" an open circuit with a megohmeter:-?
