Is this a new installation? You should be performing high-potential (dielectric-withstand) testing at a voltage level 2 to 2.5 times the nominal system voltage to ground. If you don't do this sort of thing regularly you can rent a tester or hire the job out if you are unfamiliar with the procedure.
