Hello
When Megging a motor to determine if it is good or not what is an acceptable reading on the megger that will tell you that the motor is good and everything is terminated properly (eg.. no shorts to ground). What is a minimum reading that you want to see on your megger to verify that a motor is good? Below what reading should you check your motor feeders or determine that you have a bad motor?
Thanks
Mull982
Thanks
Mull982
