mickeyrench
- edison, n.j.
We have three large sump pump motors 100 hp each 480 volt. one megged @ 2.2g.and one @ 60m. The third megged at 1meg. I did it 3x. I notice when megging and it was @ 1000vdc the voltage is usually at 1050vdc . This time when megging the voltage would go from 800-900 vdc and alittle lower and would only go to 1meg . I did it three times and changed the batteries too. Then meg the other two motors and the megger seemed to work fine.
Any ideas about this pump motor. Does the motor appear to be on the way out? It is under water when working and could the seal have failed and water enter the motor? Used a fluke 1587.
