Interesting but I disagree, recently there was a gas pump at a gas station that was tripping a breaker occasionally, first time one of the guys went out all the wires ohmed out just fine, he replaced the breaker checked connections, everything worked.
Breaker randomly tripped again, I suggested he bring a megger, one of the wires tested wayyy different than the others so he broke the seals and pulled out the wire, you could see a funny burn spot thru the black wire.
similar situation again about a month later with a sign circuit at a shopping center.
So in both cases the megger helped where a regular fluke meter showed everythings fine.
I have also used a megger to find and solve countless AFCI problems in NM cable where other contractors threw up their hands.
