laketime
Went to a customers house who had an issue with a major short in their furnace that was repaired by a "furnace guy". He repaired what ever was wrong with the furnace but in the major short one leg on the 100amp breaker that fed the furnace had burned the buss in the panel. The homeowner replaced the breaker which in turn started to melt on that same leg. They cleaned the buss and installed another breaker. That one last about 10 minutes before it melted. I was thinking it was the spot that burned on the buss causing a gap where the breaker pushes in. That gap was causing the breaker to overheat and melt at that point. I did do an amp probe reading as the unit was running and it was drawing about 50amps/leg. What do you guys think?
