We have a Solar project that contains 209 POE Metal Enclosures. I think a EGC should be connected to the metal enclosure but find NEC confusing regarding the grounding. CM states ground is connected to din rail. Wouldn't that be considered a floating ground? Below are pictures sent to me by the CM explaining his thought process as well as the engineering design. Looking for an answer to supply. If the CM and design are correct, so be it.
Thanks
CM: Below is picture of POE enclosure and how it's connected to ground.
Routing of the conductors
Auxiliary Panel connection location for tying to ground grid.
			Thanks
