We will be performing upgrades on the forums and server over the weekend. The forums may be unavailable multiple times for up to an hour each. Thank you for your patience and understanding as we work to make the forums even better.
Ill bet it's already pretty well grounded by the bazillion anchor bolts (however there may be a vapor retarder under the slab and/or footing). I assume you mean to ask if the building steel can be used as a grounding electrode and/or if the building steel is required to be bonded?
