WCoughlin
New User
- Canada Ontario
- Master Electrician
Good Morning Guys I'm currently working on a project where I'm running a 100amp branch cct from a 200 amp main panel inside the house to a panel located in the garage the frame is steel and is bolted to the concrete floor which was poured before I got the project. With that said Do I need to provide a ground rod to the structure with a loop? would I be ok with a ground rod and one point of connection or can I run a bond from the new 100 amp panel to the frame? Thanks for your time and help.
