Metal Halide inline fuse question
The purpose of fusing an HID ballast is to remove the ballast from the power line in the event of a system failure. A fuse does not protect the ballast from failing.
Fast blow fuses should not be use do to the possibility of a high inrush current. The power could be turned on at a high point in the sign wave cycle.
When using 120 volt tap for auxilary lighting a slow blow fuse should be used to protect the ballast from damage from a fault in the auxilary lighting circuit
I know its hard to co ordinate a fuse and a breaker but is a std fuse fast enough to keep from tripping the breaker and shutting down all the lights?
dick
