JCT1 said:The facility were I currently working has several obstructions (air duct, water pipe, equipment, etc.) preventing the opening of the covers on the wireway.
I NEED THE CODE THAT RELATES TO THE ACCESS AND/CLEARANCE FOR THE WIREWAY
It sounds like it can't be accessed at all...
You only have to be able to access it, it does not have to be easy.
110.26
And if you open this can of worms, guess who will be working to get these enclosures accessible. YOU!
Big difference: You can pull wire through inaccessible conduit, as long as you can access the ends.AFAIK, there is no code requiring you be able to open the covers.
No different than using conduit that you can't get into.
Disclaimer: I take 'wireway' to mean the typical trough with enclosures nippled and conduits attached.
Okay, but let's say I need to pull a new homerun through a conduit, through the wireway, and through another conduit.
How do I get the fishtape to aim from conduit to conduit through the wireway?
No comments about using a SeeSnake, thank you! :grin:
Your definition of wireway sounds more like that of auxiliary gutter.
For wireway, think trough used as raceway.
