Meter and Service Disconnect at Road - What Wires to use underground to connect main panel in house?
gz068z
Engineer
I have 200amp connection, with the meter and service disconnect at the road (see pictures). House panel is about 75 feet from the service disconnect at the road.
1) Assuming I need 4/0-4/0-4/0-2/0 AL wire sizes (considered a sub panel), exactly what type of wires are required to run from the service disconnect at the road to the panel inside the house? Getting a lot of confusing answers between URD, SER, SEU, etc.
2) Can the same wires be used to connect directly from the service disconnect to the house panel, i.e. no additional junction box, etc at the house?
3) Do I need to run this in PVC Conduit along the entire stretch, or just underground until it reaches the points where it comes up?
Image 1
Image 2
Image 3
Thanks,
Scott
