salvar774
- South Padre Island ,TX
I am a little frustrated with the power company . M.V.E. coop ( electrical distribution Co. )insist on the G.E.C. be run from the ground rod to the meter enclosure most inspectors want it run to the main disconnect and do not want a grounding wire run from the disconnect to the meter enclosure . Some want the G.E.C. run to the meter base then to the disconnect uncut .Some say from the disconnect to the meter enclosure uncut . I say the neutral should be grounded at the main disconnect only and running a grounding wire to the meter is unnecessary because doing so is like running a parallel neutral.
The inspector approved the work but the power company refuses to hook until I do their way (run the G.E.C to the meter first )
What the heck! I tell them they have no say so . I am qualified to do electrical work ,the inspector is qualified to do inspections of my work ,yet the power company service man that does not even hold a journeyman license is dictating what should be done .
I suppose it would be easier to just do it but is it right . I think not !
Is there a document I could print where it shows what I am saying ? I am meeting with the power company and I want to either change my view or theirs. Maybe I do not understand the correct way ???
