yesterlectric
- PA
- Electrician
Some safety departments are now requiring that for a meter that you use to verify that a circuit is de-energized, that the meter must have been calibrated within the last 12 months. This is I believe not an OSHA requirement but something that companies have decided to require. NFPA 70 E just requires live – dead – live and I’m sure they have something about inspecting your meter. And I think OSHA requires something similar but actually a little bit less.
Since you don’t need extreme accuracy to tell if a circuit is live, I’m wondering about the effectiveness of a typical calibration check that may be done. Does the standard meter calibration deal with other things besides accuracy? Does it involve any rigorous inspections of the meter or any inspections/tests that might help identify impending failure?
