Install a subfeed block in the combo panel, feed ATS with it. Install new subpanel connected to load side of ATS and reroute all circuits to it.
Easiest possible meter main to do an ATS. Lug block off of the main breaker, pipe into the ATS and land that on your utility terminals. Extend the subfeed that comes into the meter main, and land that on your load terminals.
If all you have is the meter and the one main you intercept the feeder to the subpanel with the ATS. If you have other loads out of the meter main those won't be able to run on the generator unless you move them to the sub panel.Thanks for the response! I don’t completely understand. I need to visualize it. I’ll be back at the job Monday and hopefully that will clear it up.
Your photo looks like you just have the one main with what we can see though.
Seems like a lot of unnecessary work for this project. The panel is not on the other side of the wall.. the ATS can handle the entire home
Would this work?
Sort of. In your combo meter main the wires going into the 200A breaker likely come from the meter.. The buss is on the load side of the breaker. This is why I suggested the subfeed block since there is nowhere in that meter main combo for you to land the conductors supplying the ATS.
In many meter main combos the "wiring" from the load side lugs to the line side of the main breaker on the panel side is rigid metal bussing from end to end. No way to intercept it except by sawing it and making holes to bolt on lugs. Clearly not supported by manufacturer.Thats the only way to legally do it. You can't rewire the factory wiring in the meter/main combo panel to connect the ATS.
Intercepting the sub panel feed makes sense. What about the utility side? The utility wire goes from the ATS to where? When the meter main are split it’s easy to place the utility wires.
