SceneryDriver
- NJ
- Electrical and Automation Designer
Since I don't do much residential work, I'm looking for recommendations on folks' favorite meter/main combos.
I'm looking to replace the clapped out meter pan on my home soon. Probably a 320/400A meter main to prep the home for EV charging. I like the idea of exterior disconnecting means as well. The home has an overhead service.
I need space for at least (3) 2-pole breakers:
200A feed for the new panel I'll put in the basement (replacing a 150A water-damaged QO panel).
200A feed for a new panel in the attached garage (shop loads and eventually EV chargers)
40A breaker for an existing 8kW solar array that's connected with a line-side tap right now.
I know people here have strong feelings on what they like and don't brand-wise.
Thanks,
SceneryDriver
Thanks,
SceneryDriver
