Meter Main with Breaker Panel Main
Woodwalker128
New member
Ohio
What is the proper hook up for a 200 amp service with a 200 amp meter main breaker? The service from the meter main breaker is 4/0 SEU going into the 200 amp breaker panel. The breaker panel also has a 200 amp main breaker. Can both of these breakers be used? I assume the meter main can be used to protect the SEU while the main breaker in the panel will act as normal. If both are used does the main breaker panel need to be treated as a sub panel, and the neutral and grounds separated?
The short answer is Yes- separate the neutral and ground- in the sub panel however I see you are a lineman and not an electrician licensed to do this work. Therefore
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
