sparky723
- Haskell,Tx
I have an Amprobe AM-16A meter.
It is 600v, CAT. 3
I have had this meter for a LONG time.I have never changed the batteries on it due to the auto off feature.
Today I was testing a guardlight (70w HPS) for power. I had the HO turn the switch on inside and then I covered the photocell with my hand until it came on. After that, I removed the lamp and tested the lampholder with the meter. When I placed the leads into the lampholder, it didnt show my voltage as I was expecting, it made a noise ( a low ziiiiizzzz) and then lit up all of the graphics that could be lit up. I had all 8's and everything at the top of the display window was on. I turned it off and then on again several times, but nothing.
I then came home and removed the batteries, put in fresh ones; cleaned the unit and put it all back together. Now when I turn it on, it doesnt do the inital "beep" telling me its on and the display is very weak looking. You have to tilt it to see anything.
This is very odd because if it is the batteries, then why doesnt replacing them work?
This meter has been an AWESOME meter and I got almost emotional when it cratered on me.
Has anyone had or know a solution to a problem like this?
Thanks, S723
It is 600v, CAT. 3
Thanks, S723
