darryljcooper
My question is this, is it permissible by the code to use a exsiting meter socket and connect into the supply side and then feed another meter socket then a disconnect150 amp for another 150 amp panel in the same building? it is a 3 phase 4 wire delta system.
If it not possible, can someone out their advise me on how i can do i? the owner of the building is going to be renting another part of his building and will be separating it by a wall.
[ May 27, 2003, 06:24 PM: Message edited by: darryljcooper ]
