hhsting
- Glen bunie, md, us
- Junior plan reviewer
Attached sketch I have apartment building as shown Bldg A, B, C which are joined together from outside but not from the inside as shown.
One utility transformer outside feeds SWBD B outside which has two feeder breakers feeding building B. The feeders go underground to come up walls of Bldg B enter level 1 Bldg B and then go inside and feed two fused disconnects. The fused disconnects then feed two meter stacks inside Level 1 Bldb B.
The two meter stacks have feeder breakers which feed dwelling unit panelboards. However the meter stacks feed Bldgs A, B, C dewelling units panelboards.
It’s confusing since. Bldg B, A, C joined from outside but not inside are they consider separate buildings or not so following questions:
1. If the feeders are routed inside the Bldg B from Bld B meter stacks to Bldg A, C dewelling units panelboards then would they need to comply with NEC 2014 section 250.32(A)?
2. If the feeders are routed outside the bldg B from Bldg B meter stacks to Bldg A,C dowelling units panelboards then would they need to comply per NEC 2014 Section 250.32(A) and 225.30, 225.32?
