enireh
- Canyon Lake,TX
a customer today said she has heard of devices that will slow the meter down
input anyone?
input anyone?
input anyone?
input anyone?
I believe the devices are called "Off Switches".
That seems vaguely familiar. I believe it only would work in a much older style of meter, perhaps many decades older than the meters used today. It would interfere with the proper operation of a meter through a magnetic interaction. It would cause the meter to report a lower usage of energy than the building was actually using. It was, of course, illegal to use.a customer today said she has heard of devices that will slow the meter down
I don't think that would have a significant impact on the meter reading. Loose connections can cause heating, which in turn can cause fires. Loose or disconnected neutral wires can cause the voltage on one or more devices to be far higher, or far lower, than normal, leading to equipment failures. But neither circumstance would result in a higher current flow.what if everything electrical is giving a once over and tightened down like it should be? if connections are not tight that can cause more current to be drawn?
graciasThat seems vaguely familiar. I believe it only would work in a much older style of meter, perhaps many decades older than the meters used today. It would interfere with the proper operation of a meter through a magnetic interaction. It would cause the meter to report a lower usage of energy than the building was actually using. It was, of course, illegal to use.
Not enough to be really noticeable.what if everything electrical is giving a once over and tightened down like it should be? if connections are not tight that can cause more current to be drawn?
input anyone?
I know of a hotel in Mexico where a former owner had put some sort of device in the meter can that slowed down the meter. It was magnetic in design, I believe. It was there unbeknownst to the friend of mine who bought the place, and years later when the utility came to upgrade the service they found the device. They were not amused and the fines and recovery fees were huge.
Only motor loads and some power supplies and lighting ballasts will react to reduced voltage by drawing more current. The losses in bad connections would have to reach the point where they are smoking before the lost power will noticeably affect your meter reading.
Some people will try to tell you that adding in Power Factor Correction capacitors will slow the meter down. It will not.
Exactly. A watt is a watt is a watt.I don't think that would have a significant impact on the meter reading. Loose connections can cause heating, which in turn can cause fires. Loose or disconnected neutral wires can cause the voltage on one or more devices to be far higher, or far lower, than normal, leading to equipment failures. But neither circumstance would result in a higher current flow.
Heat is current. And heat is hard on devices. So the old torque once over is a great idea!Not enough to be really noticeable.
