Quick question...I have a 277/480 service that ive been saddled with outta nowhere. anyway Had the utility companies planner come out and go over the requirements for the service. HE is making us replace the meter can...add a discon before the meter and put it all on unistrut. I agree his recommendations except the meter can. ( there was nothing wrong with the existing) any way after completing the service and having it pass inspection, the guy tell me that the unmetered and metered wires cannot be in the same channel...( meter is a 7 pin levered bypass meter can.) the only space in the socket is on the left side opposite the lever and top and bottom. because the trough is below the meter and the discon is before the meter i had no choice but to route the wires in the same channel... normally it wouldnt be a problem to reconfigure but we have to turn the store over in 2 days and the utility company requires a 2 week minimum to schedule an outtage!!! is there any credence to his gripe? my idea was to cut lload side conduit up top 2 ft to the left bring it down and enter the meter on the bottom ...then the metered and unmetered wires would not be in the same "channel" as they are in the pic...the only place they would be is at the bottom where there is much more space. ( please disregard the card board spacing...used that to get the damn wire out the way so i could get to the lugs).
for reference The gear in the middle is my installation with the discon.
THis IS the planner suggestion which qould work but would require an outtage to be scheduled for the whole Mall
This is my suggestion ...will this work and is it allowed?
