Re: meters
Come on guys, you know there has to be a real reason for meter socket height requirements, other than the height of the meter readers!
In my city, the rule adopted is 5'6" to the center of the socket. This is the necessary height to put the meter reader into a safety zone if the meter shorts out upon installation or removal.
To install a meter correctly, you hold it securely, pushing the bottom stabs in first, then the top. If there is a short, the force of the arc will be directed upwards and not into the face of the meterman. If the height is lower than 5'6", it would be real easy for the meterman to be looking down into the socket when installing the meter.
It is also ok to install the upper meter stabs first, and the same prinicipal applies, but the direction of the arc will be downwards, into the body area, and away from the face.
Of course, all of this is moot if the service in not energized, or if correct PPE is used. How many of you guys install or re-install a meter in a dead socket? I bet not many. How many of you guys were the required protective clothing while installing a meter into a hot socket? Again, not many.
In my city, this requirement for the meter socket height has been in effect for at least 30 years, and, for the most part, is followed. However, there are a few instances where it can not be followed, such as meter pedistals, or in alleys where vehicle traffic might cause damage to the meter, or, like the above posts state, meter stacks. Prior approval is required for these cases.
My point is to think about the safety aspect of this, not that the power company is starting to hire short meter readers!!!!!
Rick Miell
