iaov
- Rhinelander WI
Does it realy matter wich way the POCO meter is hooked up. On overhead services here the line is the top but on underground the load goes to the the top lugs. Does anyone know how/why this is?
The electronic meters will work just fine if they are installed upside down and there is nothing to stop power from passing through in either position. The mechanical meters will indeed run backward or not run at all in installed upside down. :smile:. . . I think the new electronic meters won't function or pass power if they're connected wrong. . .
Yes it does matter..if the connections are transposed the older mechanical meters will run backwards. An old trick to reduce electric bills was to unplug the meter and turn it upside down to make it run backwards. Of course the penalties were on the severe side when the POCO caught it. I think the new electronic meters won't function or pass power if they're connected wrong.
That should be very incorrect.. . . on underground the load goes to the the top lugs.
And they still charge you a reconnect fee.it can also be turned off remotely. don't pay the bill? click. dead in the water.
There is quite an up-charge for that feature. Unless we have to go back a lot to disconnect for non-pay, we do not have that feature. :smile:. . . it can also be turned off remotely. don't pay the bill? . .
