Metric measurements
physis
I find it somewhat offensive that the measurements we use in America are treated as second class in the NEC.
It might be a small point but it seems the NFPA thought it significant enough to specifically parenthesize our American standards as subordinate to metric.
I see on the cover it says "National" Electrical Code (America free) and "International" Electrical Code Series.
I understand the international use issue. But shouldn't it be written for us (that's US) first?
I have a feeling it would be completely pointless, because I'm thinking it's purely political, (I know European and other nations write their code for us first) but,
______________________________________This is the question_____________________________________
how could someone go about submitting a proposal to address something like this that effects the entire NEC?
charlie
Indianapolis
Re: Metric measurements
Well Sam, I totally disagree with you. I have felt like we should have gotten rid of the In./Lb. system years ago in the USA. OK, now I feel better. :D
don_resqcapt19
Illinois
retired electrician
Many federal jobs are 100% metric from the design to the drawings and the billing(if per unit). I think that congress made the metric system the official measurement for the US in the late 1800s.
Don
physis
I know that most things congress ratifies are nearly secret as far as public knowledge is concerned.
So, we're secretly measuring are conduits in milimeters? :confused:
I have to differ at least with the notion that we are using the metric system in our day to day electrical lives. Well, I mean to a large degree for most of us.
I know that it is indeed used, but, I also know how much I don't use it.
_______________________________________________________________________________
Well, anyway, so if I send a proposal off to any old CMP, or regarding any old code section, then it would go to a, or the, TCC?
Edit: I had to add something.
[ April 23, 2005, 09:30 PM: Message edited by: physis ]
charlie
Indianapolis
No, you do not send any proposal to a particular panel. You indicate the section you want changed. In this case, it is the whole code so state that you want the whole code changed instead of a particular section. :D
