Meyers Hub water tight
Although Meyers hubs are often used with PVC male adapters, Meyers hubs are intended to be used with tapered male threads. I have yet to hear of a violation.
You could use a nipple and female adapter.
Confused how I would put it in. Female adapter on top then nipple with lock nut on it.
I think what he is saying is that since the hub will not take pvc just install a rigid nipple and then convert to pvc with a female pvc adapter. That is a pvc coupling with threads in one end of the coupling
A minor note: it's a Myers hub, not Meyers, but puppies & kittens will still be born blind either way you spell it.:)
Years ago, someone searched for "Sawzall Accessories" & ended up getting a link for a sex toy. It was was not a good image, plus once seen cannot be unseen.
