Yes if you are actually using Table 310.15(B)(2)(a) with 90 C conductors you can start at the 90 C column.Originally posted by badjeepr:
i believe the 90 degree column may always be used for derating purposes but for actual ampacity rating one must use the lowest applicable temp. range
