mstrlucky74
- NJ
Don't have full story but from what I got.....
MI cable being pulled in a new construction building that's not fully closed(GC can't close it in) in. Guys worried about moisture build up due to cold and amp weather. They said they're putting rubber caps on each cable to control moisture...not sure what that means.
Do do you think their worried about the actual cable getting moist or the ends? In any case, if you know what I'm trying to describe is anything else that could be done to the cable to help control moisture on the cable? Thanks
