kingpb
- SE USA as far as you can go
- Engineer, Registered
When the behind the meter microgrid (with solar, BESS, and other generation) disconnects from the utility either at MV or LV to operate in island mode, i.e. without utility power, the utility phase conductors are disconnected but the ground is still present. If that is the case, a reference ground is still present. Why would I then need to provide a reference ground? But is that safe? Would it be best to add an electrically operated switch on the ground to isolate the ground as well and make our own reference ground? Or, can I utilize the utility ground and essentially make a ground grid and keep everything on the same reference. There seems to be a lot of confusion around grounding these facilities.
