Alwayslearningelec
- NJ
- Estimator
When you install MIGB on conduit does it go on both ends of conduit or just one......or it can vary?
I beleive I stated that when the raceway enters through a concentric or eccentric KO and the voltage is above 250 volts to ground a bonding bushing is required.Hey Inf. Just came across this. I think you said in another post they are required when terminating conduit into a box with KO when the voltage id 277 or higher?
No, but you're close.Excuse my ignorance - what is MIGB? I'm sure it isn't Molybdenum Inverse Grease Barbiturates......................![]()
Appreciated, thank you! Not something we generally use. As a rule we use multicore 90C copper conductor.No, but you're close.
Mineral Insulated Ground Bushing.
Ron
When I looked, I found Malleable Iron Grounding Bushing and Malleable Insulated Grounding Bushing.No, but you're close.
I'm sure that's more accurate than my definition.When I looked, I found Malleable Iron Grounding Bushing and Malleable Insulated Grounding Bushing.
