might be a little late but a good idea
electricalperson
massachusetts
i think they should put in writing that they require arc fault protection on lighting outlets in kitchens and bathrooms. i know in the real world people will come off of another circuit to feed those outlets but the code does not say you need it in those areas. i actually ran a seperate branch circuit to feed a ton of lights in the kitchen and i did not put those on arc faults. i dont think the inspector can fail it
What about laundry room and crawl/ attic lights.
BTW. I have heard some people are having trouble with doorbell tranies and arc fault. You may want to avoid those cir. on the arc faults.
arc fault circuits
arc fault circuits
electrical person;
unless i'm behind times the 2005 nec does not require arc faults in kitchens.
This forum is for proposals. You can make a proposal for the 14 NEC or wait until July and perhaps comment on a proposal for the 11 NEC.
By the way what you've proposed is in the 08 NEC.
electrical person;
it is not required in 2008 either - that was the OP's point.
I purposely run a separate 15amp circuit for the kitchen lighting and I have started running a 20amp circuit to each bathroom and using that circuit to feed everything in that bathroom to avoid arc's there.
I wouldn't be surprised to see the bathroom and kitchen lighting circuits added to arc's in the 2011 code
No , he can't. It spells it out for you in the 08 Handbook on page 90, bottom of the page.
