Hi everyone,
I have almost 400 protection relays in my distribution and i don't have any scada system. All relays have modbus or courier communication protocol on RS485. I want to design a scada but i don't want to use any RTU or PLC. I found a device which is named Kalkitech SYCN2000.
http://kalkitech.com/offerings/sync-field_protocol_io_gateways/
This device converts the courier and modbus protocol to IEC61850. And also device has internally programmable I/Os.
I am going to use this device to take voltage, current and power values for scada. And i am going to use internally I/Os of this device to open and close function of circuit breakers. The main idea of using this device to adapt my old system to the new technology (IEC61850) and to get out of RTU or PLC.
I attached the shecmatic of my distribution center and the structure of SCADA. Can i take your comments about this subject.
Is it a good way for old systems and old relays?
Can i use the benefits of IEC61850 with this structure?
Advantages and disadvantages of this system?
Or should i use an RTU or PLC?
