Mike Holt code questions
moondog23
I am signed up for Mike's free e-mail with monthly code questions.
Perhaps it is looking a gift horse in the mouth, but I wish they would please reference which code (1999, 2002, 2005) they are using when they answer a question. For example, the following question and answer are copied from his June questions, part 3:
Q3. Does an above the range combination microwave/hood fan require a dedicated circuit if its cord-and-plug connected?
A3. Yes [422.16(B)(4)(5)], and be sure to comply with the following as well [422.16(B)(4)]:
(1) The flexible cord must terminate with a grounding-type attachment plug.
(2) The length of the cord must not be less than 18 in. or longer than 36 in.
(3) The range hood receptacle must be located to avoid physical damage to the flexible cord.
(4) The range hood receptacle must be accessible.
Perhaps that is the 2005 code. I live in California, and we just recently adopted the 2002 Nec as a part of our 2004 California Electric Code (CEC).
His answer is not applicable to the millions of people in California, ( a dedicated circuit is not required in the 2004 CEC.) I believe referencing which code book is being used is something that would be very helpful and provide clearer communication.
Mike has viewers nationwide, not just Florida. We are not all using the same version of the code. Just another price of his success!
Is this an issue with anyone else?
Moondog I assume anything a code consultant tells me is based on the latest published codes unless otherwise specified.
Moondog,
It seems that the problem you and millions of others have, is with California adopting a code that over four years old, not with Mikes' answer!
Is it so hard to figure out on your own?
We aren't even on the 2005 NEC here in Florida, so your argument doesn't hold up. Get with the times or get out!
Complaining about a free service is ridiculous. I'm sure Mike and all the persons that assist Mike in putting out his products would just prefer a Thank You.
In all of Mike Holt's articles in ECM, they are prefaced with the statement all references according to the 2005 NEC or something along those lines.
Pretty much, all discussions around here are based on the 2005, unless otherwise mentioned.
I guess you're living in a 2005 world, better get used to it. :D
