I just want to check my sanity...
I am going to be testing some transistors in a lab very soon per the above mil std. The test methods range from Vce, Vbe, hfe and the breakdown voltages that are listed on the datasheet. The transistor at this point is irrelevant.
Here's what I need to understand. According to the mil std, the circuits are all drawn for PNP trnsistors in one configuration. That's fine. However, I will most,likely be testing NPN transistors. So, if I understand this right, all I need to do is reverse the polarity of the sources and test equipment (ammeter, voltmeter) in order to correctly perform the tests per this std. Is this right?
