Miller welder over seas
Dbronx
Colorado
Data:
Miller 200/300 AMP
single phase
220 volt
50/60 HZ
70 amp MCB
Avalible voltage 400 volts
230 volts phase to ground
Can I connect 230 volt phase to L1 and neutral to L2 on welder, will it work and how long?
It should work just fine. I used to live in Macau when I worked for Cirque du Soleil, and that's what we did there. All we had to do was change the plug to match the local outlets.
