They will, if you are willing to pay for it. Why don't you just call them and ask?kalanjeya said:. . . will they arrange for higher voltage ?
kalanjeya said:Hello all,
I am a kid in this field and interested to learn a lot. Could you tell what is the minimun requirement for the project needs to get 277/480 V. (because I am familier in designing only 120/208V , I never crossed the voltage).
petersonra said:it is common to put in a 208V/120 service and add transformers inside the building to feed 480v loads.
kalanjeya said:petersonra said:it is common to put in a 208V/120 service and add transformers inside the building to feed 480v loads.
Will you step up the volts from 120/208V to 277/480V ?
I am working for a company in Virginia, When i design a apartment building which is includes some retail shops, would this 120/208V service used for commercial purpose comes under normal tarrif or commercial tarrif ?
kalanjeya said:Could anyone provide more suggestion on this ?
Right. The higher-current, lower-voltage gear also has a cost differential. You have to compare the costs of doing it both ways, including POCO charges.augie47 said:As others have stated, there is a sizble cost increase for 480v gear. You must offset that by comparing wire sizes, starter sizes, voltage drop, losses from in-house trasformers, etc.
