Mini Split 14AWG Control Wire Question
SNS
New User
Seattle, WA
Architect
We have purchased a two zone LG mini split and I am pretty straight on all the power requirements for the outdoor units and those coming to the indoor units. My question is about breaking up the power/signal wires running from the OD unit to the ID units; that is what I am seeking input on.
I will have two head units, so a power run to each and a control run to each. I've read in their installation manual that you can run 14/4 up to 132' - but I have also read both in the installation manual and elsewhere that it's better to separate the power and signal lines. This entire project is a lot of work, and in getting conflicting information and am thinking to just choose the most conservative path by running them apart; power lines with the line sets and condensate drain and then the control lines in their own hard conduit, separate wall penetrations, routed separately from the line sets/power to the head units, all the way, etc.
Right now I am planning on using 14-2C Type MC for the power connection and them am planning to run some other 14AWG (perhaps shielded) for the control lines.
My questions:
  • Is my taking such an approach a good idea to remove the potential of signal conflicts or is it overblown?
  • Since the 14AWG is only for controls, can I be more flexible on the wire type (shielded 14AWG speaker wire)?
Thanks for your help!
//sns
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the button at the bottom left corner of the post.
