Jimmy7
- Boston, MA
- Electrician
I need to wire a mini-split in a single family house. Between the inside and the outside unit the hvac contractor already ran ducktstrip wire. Rather than just running the cable exposed from where it exits the house to the outdoor unit I didn’t know If I should sleeve it in non-metallic liquid tight. If I do sleeve it, what is the best way transition to non-metallic liquid tight where it leaves the house, use a nonmetallic bell box? If so, what can I use on the back of the bell box for a fitting? Do they make a nonmetallic chase nipple?
duckt-strip.com
Home • Duckt Strip
DUCKT-STRIP® MAKES INSPECTORS HAPPY. Inspectors who know about Duckt-Strip® recommend it 100% for Mini-Split installations because, simply, it makes sense. Why risk getting it wrong, when Duckt-Strip® gets it right. Learn More SEND US YOUR VIDEOS!
