jhort
New User
- California
- Handy man
Hello all. Wanting to install Gree mini split 12000 btus 220 volts. Wire run has been done already from breaker panel to outside wall near where exterior unit will be placed. I believe wire is 10/2 with ground. It's yellow sheath.
The wire comes down the wall in a conduit from attic and ends in a junction box. The wire enters the box in the conduit from the top. The box though is solid. No knock out holes. Has a front cover with 4 screws. Inside the box, the 10/2 is just coiled up inside. There is nothing in this box to connect anything.
Is this a temporary box? I was expecting a box with knock out holes to wire up the whip that goes to condenser. Also, if another box is needed, my search for a box does not yield any boxes that have an opening at the top so that wire can be fed through there. I wish i could post pics.
Any ideas, suggestions, advise, comments appreciated. Thanks
