Mini-split Roof Condenser- Disconnect Mounting Location
designer82
Boston
I have a disconnect switch for a simple Mini-Split condenser on the roof.
Is it acceptable practice to mount the disconnect right on the condenser itself or should this be mounted not directly on the condenser?
Thanks
It's acceptable but whether or not it's advisable is another question. Mini-Split condensers are usually small with little room to put one. And if you do you have to be careful of what's inside that you may hit with the screws.
-Hal
