depawl52
- Upstate NY
- Engineer
I know this issue has been addressed previously/elsewhere, but it keeps coming up on projects I've been involved with. Most of the mini splits I've seen have a "Max Fuse" amperage listed on the name plate. I'm of the opinion that this requires a fuse to be installed somewhere in the circuit (normally at the disconnect at the outdoor unit), as opposed to a breaker of the listed amperage. For example, if the mini split name plate lists a Minimum Circuit Ampacity of 15 and a Max. Fuse of 15, my take would be a minimum 15 amp breaker at the main panel, and a 15 amp fused disconnect. Is this correct?
Thanks.
Thanks.
