Not me. Good luck!Has anyone come across a mini split unit that requires a 4 conductor power supply?
I’m talking circuit from load center to disconnect not from unit to indoor head.
Thanks
No but can you provide an example?Has anyone come across a mini split unit that requires a 4 conductor power supply?
Thanks
It may be what could be called a “universal terminal strip”, instead of having three possible terminals, four are used, so the instructions would be simplified by terminal number, and the unused terminal would not be connected at the factory when it was built, depending on voltage it was shipped as. Just something to speed up production most likely. Only one terminal label would be required.Appears to be misinformation on their cut sheet.
It was showing a neutral being required but it was supposed to be in the column only for 120V supply but was also in the 240V column.
