Re: minimum bending radius THHN
ChristianD, welcome to the forum.
Originally posted by ChristianD:
...the code tries to lead you away from makeing any more bends than needed by haveing restrictions on some bending radius.
I don't believe the restrictions are to keep unnecessary bends out of the cables. I think the requirements are there to prevent damage to cables by extreme turns that would pinch the cable, causing heat buildup in a spot in the cable.
For example, take a piece of #14, put a little scratch in it with your dykes. If you start bending the conductor back and forth in that area, it will break there. That's a weak spot.
While not a rock-solid analogy for the principle I visualize, I assume it's something along those lines. When you take a hard, abrupt turn with a cable or conductor...
...Picture a pipe. Bend it in half, at a hard 90?. In general, there is more material at the inside of that bend than the outside. Now run current through it. I'd imagine the resistance of one edge of that bend in the pipe is different than the other. In the difference is heat difference. In the difference, there's stress. There's heat, stress, bad things for a current carrying conductor.
It's a flimsy analogy, but it's kinda what I picture when I think of a kink in cable.
When you say, "unnecessary bends", it brings to mind the 360? rule as it applies to conduit, and that's definutely a different concept than the one in place for cables.
Hopefully some better analogy-makers can pitch in and correct me or augment my statements.
