hardworkingstiff said:Less voltage drop.
Higher amperage available at an outlet.
You are going to have to break out the calculator for me here....a longer length of wire (albiet one size larger) will have less VD than a shorter wire?
Higher amperage....the device is limited to the 15A....how do you squeeze more out the slots? [ T210.21(B)(2) ]
You might also want to consider the cost aspect....screwing #12's vs backstabbing #14's.
