Carultch
- Massachusetts
Is there an NEC requirement about the minimum height of a disconnect, where it is in a region subject to snowfall?
What about readily accessible, in the NEC2014 definition? Does snow count as an obstacle you need to remove, in order to access a device that is otherwise "readily accessible"? What about "within sight"?
I have a situation where NEC690.15 applies to inverters mounted on a rooftop, and the person reviewing my drawings is challenging me on mounting the inverters 2 ft above the finished roof surface.
Certainly they are not "readily accessible" from the ground, but in the event that inverters are not readily accessible from the ground, NEC690.15 requires that the corresponding disconnects be "readily accessible" and "within sight" from the inverters.
