Minimum general lighting load
DimlyLit
Seattle, WA
Electrician 4y
I just finished an Administrators test and was completely stumped by a question:
"What is the minimal general lighting load for a residential structure?"
There was no Sq ft suggestion, nor anything to indicate the size of the structure. Am I missing something obvious here?
Yes 3 watts per square foot is the amount, but there was no square footage given! Table 220.12 is for wattage per square foot in a whole number of locations and usages, but again one needs the square footage to determine the amount. But there was no square footage given. Is there some obscure note in the NEC for minimum square footage for a single family residence that I am not aware of?
ps. The four answers given ranged from the hundreds of watts into the thousands of watts.
"The four answers given ranged from the hundreds of watts into the thousands of watts."
In that case I see what your saying.
Hard to ansawer that one.
All " D"
Maybe work 220 backward based on the minimum service size for a residential service.
Even at that rate more information would help solve.
I would also like to add that it should have been in VA not watts.
One could look in annex exames and see if one of those matches an answer based on 230.79 (C).
"Yes 3 watts per square foot is the amount, but there was no square footage given! Table 220.12 is for wattage per square foot in a whole number of locations and usages, but again one needs the square footage to determine the amount. But there was no square footage given. Is there some obscure note in the NEC for minimum square footage for a single family residence that I am not aware of?
ps. The four answers given ranged from the hundreds of watts into the thousands of watts."
The Watts per square is a rate. You don't need to give a specific area.
Wonder if this is a question based on given information for multi part answers.
I took a test once where it used one question and ask several others related to the info.
It had to do with service calculations.
I was wonder if it was worded: based on the above information, then the question.
Could it be Table 220.42 they are relating to.
I would think both tables apply.
"I would think both tables apply."
I don't think so. It is just the rate that applies.
"What va were given to you?"
Why would you need that? The question is for Watts per square foot.
We use VA for calculating from 220.
Since the answer was in watts, I would think there had to be more information given and or looking for an answer from another question where the watts were provided.
either way I would consider writing them for help and protest the question if the NEC was listed as a accepted material for testing.
Based on 220.12
from 2107 NEC:
220.12 Lighting Load for Specified Occupancies. A unit load
of not less than that specified in Table 220.12 for occupancies
specified shall constitute the minimum lighting load. The floor
area for each floor shall be calculated from the outside dimensions
of the building, dwelling unit, or other area involved. For
dwelling units, the calculated floor area shall not include open
porches, garages, or unused or unfinished spaces not adaptable
for future use.
Informational Note: The unit values are based on minimum
load conditions and 100 percent power factor and may not
provide sufficient capacity for the installation contemplated.
Also as why not use watts.
220.18 Maximum Loads. The total load shall not exceed the
rating of the branch circuit, and it shall not exceed the maximum
loads specified in 220.18(A) through (C) under the
conditions specified therein.
(A) Motor-Operated and Combination Loads. Where a circuit
supplies only motor-operated loads, Article 430 shall apply.
Where a circuit supplies only air-conditioning equipment,
refrigerating equipment, or both, Article 440 shall apply. For
circuits supplying loads consisting of motor-operated utilization
equipment that is fastened in place and has a motor larger
than 1∕8 hp in combination with other loads, the total calculated
load shall be based on 125 percent of the largest motor load
plus the sum of the other loads.
(B) Inductive and LED Lighting Loads. For circuits supplying
lighting units that have ballasts, transformers, autotransformers,
or LED drivers, the calculated load shall be based on the
total ampere ratings
of such units and not on the total watts of
the lamps.
Then we have this for Dryer and Ranges.
220.54 Electric Clothes Dryers — Dwelling Unit(s). The load
for household electric clothes dryers in a dwelling unit(s) shall
be either 5000 watts (volt-amperes) or the nameplate rating,
whichever is larger, for each dryer served. The use of the
demand factors in Table 220.54 shall be permitted. Where two
or more single-phase dryers are supplied by a 3-phase, 4-wire
feeder or service, the total load shall be calculated on the basis
of twice the maximum number connected between any two
phases. Kilovolt-amperes (kVA) shall be considered equivalent
to kilowatts (kW) for loads calculated in this section.
220.55 Electric Cooking Appliances in Dwelling Units and
Household Cooking Appliances Used in Instructional
Programs. The load for household electric ranges, wallmounted
ovens, counter-mounted cooking units, and other
household cooking appliances individually rated in excess of
13∕4 kW shall be permitted to be calculated in accordance with
Table 220.55. Kilovolt-amperes (kVA) shall be considered
equivalent to kilowatts (kW) for loads calculated under this
section.
Any way hard to answer a question without good information to base it on.
I would go get my points for the answer and have done so in the past.
If I am owed I collect.
If I owe I pay.
What's an Administrators test?
Could the answers be based on something other than the NEC? Energy code? State or local ammendment?
If the answer is supposed to be based on the NEC or an unammended version of Art 220 ... then I think it's BS question.
Your in WA.. 2020 NFPA 70
See Chapter 2 Article 220
220.14(J). Dwelling Units.
*Pay close attention to first & second sentences.
