B
bthielen
Guest
Can someone help me? I will admit that I am not a journeyman or master electrician however I am an electrical designer and am accustomed to using the NEC and other codes such as NFPA, CE, UL, etc. I've been trying to find information in the NEC about wire protection in a building where animals may be loose. This is an agricultural building, on my own premises, and is considered a corrosive atmosphere due to the animal habitat so I am using type UF wire and corrosion resistant watertight boxes as required. What I am trying to determine is if it is required that I enclose the wire in conduit below a certain minimum height. I will be mounting a few receptacles and light switches within 6' of grade.
I was also informed by my inspector that if I pass the wire through a wall I must use conduit to protect the wire from mice and other similar animals. Of course I will satisfy his requirement and it makes sense but I am curious, where is this written in the code? I haven't been able to find it.
Any help is much appreciated. Thanks,
Bob
Bob
