MINIMUM OF 4-WAY SWITCHES
dannyrzk
tulsa, OK
Good morning. i being searching and so far I haven't found nothing that limit the amount of 4-way and 3-way switches I can use in a room, or controlling a set of lights. Can't anybody please tell me if there is a minimum of switches, that can be use, or does it matter at all?
Thank You
Thank You
The number of 3 and 4 way switches you use is a design issue and not a code issue.
I normally limit the number of 3 and 4 way switches to the number the customer is willing to pay for. In most cases that isn't to many.
Thank You
AFAIK, you are stuck with two 3-ways per 'set' of lights, but can have any number of 4-way switches.
161128-1030 EST
A three-way circuit consists of exactly two SPDT switches.
If you add one four-way switch to a three-way circuit, then you have three switching points. From this minimum you can logically add as many more four-way switches as desired to increase the number of switching points.
What is a four-way switch? Internally it is a DPDT switch with the addition of some cross wiring. Instead of the six terminals of a DPDT switch it only has four terminals. Easier to install for this application than using a true DPDT switch.
We did one house where we had at least four seven gang boxes with three and four ways in them. They wanted to be able to control a bunch of different lights from a bunch of different places.
With today's technology there are definitely better ways of controlling complex lighting systems.
